Old 03-10-2015, 11:38 AM
shall6 shall6 is offline
Question Vizard Matlab interface - no data printing
I've been trying to set up a way for matlab to talk to Vizard. Eventually, I want to be able to take sensor data that is real-time processed in matlab and use it in Vizard. Right now I'm just trying to set up a simple UDP connection. This is what I have:
MATLAB:
ip = 'LocalHost'; port = 4950;
u = udp(ip,port);
fopen(u)
fprintf(u, 'testdata')
Vizard:
import viznet
dataNetwork = viz.addNetwork('LocalHost');
def onNetwork(e):
if isinstance(e,viz.RawNetworkEvent):
print e.raw_data
viz.callback(viz.NETWORK_EVENT,onNetwork)
Nothing prints in Vizard. It just loads. I tried running the matlab code and the Vizard code in different orders. I've sent the matlab "fprintf" command again, then I run the Vizard code again. Matlab claims something sent, but I don't see it.
Eventually, I want to change "print e.raw_data" to "var = e.raw_data" and save the data as a variable, "var", then use the value of "var" as a command, the same way I would use a keyboard button-push.
What am I missing, and will saving as a variable work when it gets going?
Thank you,
Sherrie
Interface between Matlab and Vizard Shweta Vizard 8 06-30-2014 10:40 AM
Iinterface between MATLAB and Vizard suraj Vizard 7 07-17-2012 10:02 AM
MATLAB and vizard xingtzu Vizard 1 01-15-2008 11:25 AM
Matlab and Vizard brystewa Vizard 1 09-18-2006 04:11 PM
MATLAB and Vizard eagleman Vizard 4 06-10-2005 12:42 PM
