Old 01-22-2015, 01:01 PM
Ryvan Ryvan is offline
Hi! Thanks for your reply.
I'm trying to create a program where a person sees a shape and they toggle it off. Then they move in a certain direction and have to point to the remembered location of the shape, which is then toggled on to see if they are correct.
Currently when I run the program the shape stays centered in the view instead of remaining in a fixed location on the plane. I was hoping that as I moved in any direction that I could move past the shape.
I hope that helps to clarify what I mean.
Thanks for your help!
mainview, movement, newb
How to get real time position of a object which is connected to a haptic device Melody Vizard 4 09-15-2014 02:35 PM
Create object with position relative to user head, but cannot be obstructed by others Notch Vizard 2 03-03-2014 07:16 AM
Object + InteriaCube + Viewport problem Gekitatsu Vizard 1 02-22-2012 10:55 AM
Can you link the position of a tracker to the orientation of an object? michaelrepucci Vizard 1 09-19-2008 10:23 AM
picking problem... k_iwan Vizard 2 07-27-2007 07:57 PM
