Old 10-27-2014, 06:07 PM
The vertices of a morph target work as a target position for each vertex of the base mesh. Morphing is always done relative to the current position of the vertex. This 1 to 1 repositioning is based off the vertex’s internal ID number, so, both the original mesh and the morph target must have the same number of vertices and the exact same vertex order. In other words, morph targets should be made from a clone of the original mesh. Making cuts, detaching faces or merging any objects will render the object invalid as a morph target because these affect the vertex order and vertex count.
Once you have your morph targets made, add a Morpher modifier underneath the Skin modifier on your original mesh. While this is not necessarily required for making morphs, it allows you to place them off on the side and test them from within Max. If it works correctly in the Morpher modifier, it should also work correctly in a Cal3D avatar. Does it work in the Morpher modifier for you?
avatar, cal3d, material, morphto
Exporting Avatar Mesh Crashes 3DSMax dthomas Vizard 1 03-18-2012 04:37 PM
Problems exporting with Cal3D Deltcho Vizard 1 08-03-2010 04:27 PM
Texturing Avatar head problems S.Telemaque Vizard 0 04-01-2007 11:01 PM
avatar animation problems jrodman Vizard 1 01-18-2006 10:12 AM
Problems with 3DMeNow Avatar Heads kim_swinth Vizard 9 11-19-2003 03:14 PM
