#15
No, if the viewpoint is offset from the wheelbarrow the viewpoint collision won't work here. You can control the wheelbarrow directly and link the viewpoint to it with an offset. The wheelbarrow's height has to be manually adjusted each frame according to the height of the ground to go up the ramp. You can use the viz.intersect command to help determine the height of the ground.
| Tags |
| avatar, climp, collision, ramp |
| Avatar Material Problem | Erikvdb | Vizard | 1 | 03-04-2014 04:46 AM |
| Unexpected Avatar lookAt() behavior when using yield statements | chris2307 | Vizard | 2 | 12-17-2013 03:58 AM |
| .osg biped avatar problem | alvinadi | Vizard | 3 | 12-20-2011 11:29 AM |
| Avatar speaking problem | Uttama_vizard | Vizard | 4 | 03-23-2009 12:29 PM |
| Problem with letting an avatar face towards another avatar | ghazanfar | Vizard | 2 | 03-21-2007 03:30 AM |
