Old 06-11-2014, 08:20 AM
mshukun mshukun is offline
Oculus <hmd>.addMessagePanel
Thank you very much for adding Oculus addMessagePanel in the Vizard 5!! I have a couple of questions regarding "addMessagePanel".
Q1: Can I change message in the "addMessagePanel" without removing and recreating "addMessagePanel" object (e.g. info_panel.message("Hello"))?
import viztask
import oculus
questions = ["Q1:", "Q2:", "Q3:"]
hmd = oculus.Rift()
viz.link(hmd.getSensor(), viz.MainView)
def test():
    for index in range(len(questions)):
        if index <= len(questions):
            yield viztask.waitKeyChar("q")
            print questions[index]
            #Create the message panel
            info_panel = hmd.addMessagePanel(questions[index], pos=(0,0,3))
            yield viztask.waitTime(2)
            #Remove the message panel
            info_panel.remove()
viztask.schedule(test())
Q2: Are there any ways to set visibility to be ON/OFF for the "addMessagePanel"?
Thank you in advance.
Makiko
Oculus Rift and 360 Panorama with Vizard Lite Edition mshukun Vizard 4 11-10-2015 11:17 AM
Oculus Rift Fullscreen teklab Vizard 6 05-21-2014 06:11 AM
oculus rift and inertia cube interaction problems apboone Vizard 4 03-13-2014 10:45 AM
Html and vizlink on Oculus HMD mshukun Vizard 3 10-30-2013 09:56 AM
Oculus HMD's setViewport() doesn't work jacky Vizard 1 09-25-2013 02:50 PM
