Old 12-09-2013, 07:30 AM
Hi Patrick,
Rounding off is pretty easy:
numbers = [179.3428955078125, -69.40995025634766, 88.83070373535156]
for i, number in enumerate(numbers):
	numbers[i] = round(number,1)
print numbers
However, I don't know if that will result in smoother tracking, because the coordinates will not be on a continuum. However, you can always try .
Another option to smooth your tracking would be to (re)calibrate your tracker, or to decrease the distance from your tracker to your tracking device. Good luck!
Importing Vicon Tracker Data ChrisMa Vizard 3 09-23-2013 10:46 AM
Use saved text file data as replay sources problem mizutani_jun Vizard 4 10-14-2010 04:49 PM
vicon pluglin - cluster problems Andy Vizard 2 11-10-2009 01:04 AM
Integrating InertiaCube and Vicon data roman_suvorov Vizard 10 05-20-2008 04:30 PM
tracking using quaternarion data jfreeman Vizard 2 06-01-2005 08:48 AM
