Old 06-04-2013, 03:54 PM
You can use the viz.max_frame_rate option to control the frame rate. For example, to force the frame rate to 60Hz, you would use the following code:
viz.setOption('viz.max_frame_rate',60)
Keep in mind that this just artificially lowers the frame rate by introducing a delay at the end of each frame. It does not perform any syncing with the display. If you haven't done so already, you should make sure your graphics driver is up to date.
Frame rate issue kopper Vizard 2 06-09-2013 11:53 AM
what is causing (a) slow frame rate and (b) spontaneous NVIDIA stereo off billjarrold Vizard 0 07-11-2012 02:25 PM
Error: failed to sync frame with following clients ecoastjohn Vizard 3 09-14-2009 02:58 PM
how frame rate varies? chepotenza Precision Position Tracker (PPT) 4 04-05-2009 04:18 PM
quad buffered frame rate confusion michaelrepucci Vizard 11 09-17-2008 09:55 AM
