Old 05-10-2013, 01:31 PM
mshukun mshukun is offline
Thank you very much for your reply. I would like to draw all vertices onto each cube face image and then save them as new image files (in order to record and display where a user throws a ball in a 360 degree interactive environment). By analogy, in Google maps one can create place marks and store it as an image file. In my case, I am trying to perform the same essential function in a cube map (since place marks are added using HMD, users freely look around and add place marks onto 360 panorama images). All place marks x, y and z coordinates are then stored in database to populate all place marks and save them as a new image file for each face for later analysis -- at least that is my goal of what I would like to accomplish.
I would like to apply 2D texture coordinates (s and t) instead of 3D so I was thinking bottom left [0,0], bottom right [1,0], top left [0,1] and top right [1,1] for each face image should serve my needs, and I thought this would be the default texture coordinate system for a cube map, but it appears I was incorrect. Therefore, how do I set 2D texture coordinates for a cube map? I suspect the answer will require considering axis direction (e.g. Positive X : -Z(s), -Y(t), Positive Z: +X(s), -Y(t) and so on).
I believe finding the texture coordinate is the best method to achieve my purpose, but if you have any suggestion or guidance, it would be greatly appreciated.
Thank you again.
360 panorama image cube using as darts target and record the xy coordinates mshukun Vizard 2 03-14-2013 07:17 AM
Haptic touch texture coordinates yth Vizard 0 06-02-2012 04:40 AM
Avatar texture swaping sleiN13 Vizard 5 06-24-2011 01:48 AM
