Old 04-05-2013, 11:37 AM
Your code is applying the shader to all objects in the scene. It seems like you should be applying the shader to the quad that is rendering the rendered texture instead:
quad1.apply(InvShader)
quad1.apply(viz.addUniformInt('InputTex',0))
Also, you might want to consider using the vizfx.postprocess library. For example, here is your script converted to use the library with the built-in inverse color effect applied:
#Adding WebCam
video = viz.add('VideoCamera.dle')
cam = video.addWebcam()
#Adding piazza environment to Scene2
piazza = viz.addChild('piazza.osgb')
#Adding & setting quad to Scene 2
quad2 = viz.addTexQuad()
quad2.setScale(2,1.5)
quad2.setPosition(0,2,6)
quad2.texture(cam)
#Apply inverse post-process effect
import vizfx.postprocess
from vizfx.postprocess.color import InvertColorEffect
vizfx.postprocess.addEffect(InvertColorEffect())
multi pass, multi-pass, multipass, rendering
Rendering order? vOliver Vizard 3 09-29-2010 02:07 PM
rendering level shahramy Vizard 1 07-26-2010 12:12 PM
how to control vizard rendering shahramy Vizard 0 07-23-2010 10:50 PM
Any way to increase rendering resolution v-Salik Vizard 3 09-12-2007 04:57 PM
Texture map rendering problem JRichizzle Vizard 4 03-04-2004 07:20 AM
