Old 04-04-2013, 12:50 AM
sleiN13 sleiN13 is offline
I've tried to get the Z800 working on a 64 bit OS but never succeeded. Emagin support is minimal to none existing. Only solution I found was switching back to a 32 bit version of windows 7. You also need to run Vizard with administration rights to let the plugin function correctly. I've also have a custom build z800 vizard plugin but I'm not sure anymore if this was because I needed some extra functionality or the vizard plugin didn't work correctly. The emagin SDK pdf should provide enough information if you need to write your own plugin.
emagin z800
eMagin HMD Quad buffer problem Shay Vizard 1 11-30-2012 12:00 PM
emagin z800 3D display shahramy Vizard 1 01-11-2012 04:04 AM
Emagin Z800 sleiN13 Vizard 8 01-07-2012 06:47 AM
emagin Z800 hyde Vizard 1 09-21-2011 02:06 AM
Emagin Z800 problem michaelinTX Vizard 5 07-12-2007 05:18 AM
