Old 04-02-2013, 05:45 AM
kartoffelsalat kartoffelsalat is offline
eMagin Z800 Windows 7 64 bit problem
I want to use my eMagin Z800 3DVisor Tracker Device with Vizard under Windows 7 64-bit.
But I can not install the USB-drivers.
When I install and run the Z800 3DVisor Software Utility it shows a message "Sensor Init Error".
When I install and run the Setup Wizard, it crashes with this error message (it is longer, don't know if you need it): "An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)".
So i am not able to install the USB-driver for my Windows 7 64-bit system and because of this I am not able to use the tracker with Vizard, which fails to connect to the tracker with this error message: "ERROR: Could not connect to eMagin device. Error: 80000016", using this line:
hmd = viz.add('emagin.dls')
I also tried the installation tricks for Windows Vista (Device Manager, update driver), but this also does not work.
Can anyone help me with this issue?
kartoffelsalat
emagin z800
eMagin HMD Quad buffer problem Shay Vizard 1 11-30-2012 01:00 PM
emagin z800 3D display shahramy Vizard 1 01-11-2012 05:04 AM
Emagin Z800 sleiN13 Vizard 8 01-07-2012 07:47 AM
emagin Z800 hyde Vizard 1 09-21-2011 03:06 AM
Emagin Z800 problem michaelinTX Vizard 5 07-12-2007 06:18 AM
