Old 03-22-2013, 02:54 PM
If you want to view it fullscreen, then you're better off implementing the shader as a post-process effect:
viz.add('piazza.osgb')
NEAR = 0.1
FAR = 200.0
from vizfx.postprocess.effect import BaseShaderEffect
class DepthEffect(BaseShaderEffect):
	def _getFragmentCode(self):
		return """
		uniform sampler2D vizpp_InputDepthTex;
		uniform float near;
		uniform float far;
		void main()
			float d = texture2D(vizpp_InputDepthTex,gl_TexCoord[0].st).r;
			float z = (2 * near) / (far + near - d * (far - near));
			gl_FragColor = vec4(z,z,z,1.0);
	def _createUniforms(self):
		self.uniforms.addFloat('near',NEAR)
		self.uniforms.addFloat('far',FAR)
viz.clip(NEAR,FAR)
import vizfx.postprocess
effect = DepthEffect()
vizfx.postprocess.addEffect(effect)
depth buffer
eMagin HMD Quad buffer problem Shay Vizard 1 11-30-2012 12:00 PM
Issue Getting Quad Buffer Working nabrahamson Vizard 2 08-30-2012 09:43 AM
Does the vrpn7.dle tracker plug-in clear the udp buffer? michaelrepucci Vizard 2 09-19-2008 10:22 AM
depth perception for a DTI 3D monitor timbo Vizard 5 07-16-2008 12:23 PM
accessing screen buffer hotspur1 Vizard 3 08-22-2003 03:31 PM
