I'm going to use the regular Complete Character set, but for now I've use the male from the Complete Character set that comes with Vizard. The offset is already there in peoplemaker (after I've exported from facegen). The offset is about 20 degrees in pitch. If I change the pitch of the neckbone bij 20, I can make my face look straight ahead (which it should do in it's starting position). As you can see from the screenshots, my head looks about 20 degrees upwards.
| Tags |
| 3dmenow, custom head, facegen, peoplemaker |
| Problems with imported Facegen head | Don | Vizard | 1 | 11-04-2011 02:27 AM |
| Awkward neck/shoulder connection when adding custom head to vcc model. | vEsotu | Vizard | 5 | 10-09-2008 06:07 PM |
| adding heads to custom avatars | vAlexia | Vizard | 5 | 02-13-2007 12:14 PM |
| problems adding a custom morph head to a custom body | Greenwu | Vizard | 1 | 07-27-2006 11:32 AM |
| Creating Custom Avatar Heads | farshizzo | Vizard | 22 | 09-12-2004 10:23 PM |
