I'm not sure if it's clear on what I'm trying to do. The first attached picture contains two coordinate axis drawn on the screw. The first one replicates the coordinate system that is created in inspector with axis colored red, green and blue. The second coordinate system shares its origin with the first, but is drawn to represent the global x,y,z coordinate system.
The basis for the first coordinate system is from the matrix created from the command: Code:
<node3d>.getMatrix(viz.ABS_GLOBAL, node='Inst-1430') [ 0.000000, -0.004384, -0.008988, 0.000000, -0.000000, 0.008988, -0.004384, 0.000000, 0.010000, 0.000000, 0.000000, 0.000000, -0.381762, -0.560596, -2.557960, 1.000000 ] Code:
[-0.381762 + 0.0, -0.560596 + (-0.004384), -2.557960 + (-0.008988)] I made the assumption that using the command Code:
moveaction = vizact.moveTo(y_trans, mode = viz.ABS_GLOBAL) <node3d>.addAction(moveaction) Here is the complete code I am using to draw those axis: Code:
def draw_line(p, axis, color):
viz.startLayer(viz.LINES)
viz.lineWidth(3)
viz.vertexColor(color)
viz.vertex(p)
viz.vertex(axis)
viz.endLayer()
def debug_script():
#Data is a helper class that creates a global object to share all of our object data between scripts
part = Data.getData().parts_list[0]
global screw
screw = part.getChildren()[0]
point = [-0.381762, -0.560596, -2.557960]
x_axis = [ 0.000000, -0.004384, -0.008988]
y_axis = [ -0.000000, 0.008988, -0.004384]
z_axis = [ -0.01, -0.00, 0.00]
x_global = [1.0, 0.0, 0.0]
y_global = [0.0, 1.0, 0.0]
z_global = [0.0, 0.0, 1.0]
global x_trans
x_trans = [point[i] + x_axis[i]*30 for i in range(3)]
global y_trans
y_trans = [point[i] + y_axis[i]*30 for i in range(3)]
global z_trans
z_trans = [point[i] + z_axis[i]*30 for i in range(3)]
draw_line(point, x_trans, [1,0,0])
draw_line(point, y_trans, [0,1,0])
draw_line(point, z_trans, [0,0,1])
x_global_axis = [point[i] + x_global[i] for i in range(3)]
y_global_axis = [point[i] + y_global[i] for i in range(3)]
z_global_axis = [point[i] + z_global[i] for i in range(3)]
draw_line(point, x_global_axis, [1,1,0])
draw_line(point, y_global_axis, [1,0,1])
draw_line(point, z_global_axis, [0,1,1])
| Haptic touch texture coordinates | yth | Vizard | 0 | 06-02-2012 04:40 AM |
| How do coordinates in IS900 thransform into coordinates in vizard's world | jacky | Vizard | 1 | 08-11-2011 11:44 AM |
| child-objects in VRML-file all have the same coordinates | Sven | Vizard | 4 | 06-09-2010 03:07 AM |
| viz.vertex coordinates | lilio | Vizard | 6 | 05-16-2009 05:36 PM |
| Object rotating around world axis, not own axis | tacbob | Vizard | 1 | 02-15-2007 10:12 AM |
