Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 09-05-2012, 02:12 PM
The node.copy command will pass all extra keyword arguments to the class __init__ method. You can override the copy method in your class and have it pass all the required arguments as keyword arguments to the underlying node.copy method. Example:
class MyNode(viz.VizNode):
	def __init__(self, model, parameter):
		if isinstance(model,basestring):
			base = viz.add(model)
			viz.VizNode.__init__(self, base.id)
		elif isinstance(model, viz.VizNode):
			viz.VizNode.__init__(self, model.id)
		elif isinstance(model, int):
			viz.VizNode.__init__(self, model)
		self._parameter = parameter
	def copy(self, parameter):
		return viz.VizNode.copy(self,parameter=parameter)
node = MyNode('gallery.osgb',0)
nodeCopy = node.copy(1)
Does this work for you scenario?
inheritance, viznode
