Old 07-11-2012, 12:03 PM
DillonB DillonB is offline
No Output from InertialLabs Sensor
Hello. I am trying to modify one of the headtracking tutorials to work with a sensor from InertialLabs instead of one from intersense. Vizard seems to be able to connect to the sensor, but it does not seem to be receiving any output from the device ( line 33 prints the euler values and they are always zero). I was wondering if anyone might know why this is.
#	WorldViz Copyright 2002										#
#  This script demonstrates how perform grab the raw data 		#
#  from the head tracker plugin.								#
viz.setMultiSample(4)
viz.fov(60)
import vizinfo
vizinfo.add('This script demonstrates how to perform manual head tracking.\nIt will retrieve data from the tracker and only rotate the yaw.\nBy default this script will connect to an intersense.\nPress the \'r\' key to reset the tracker')
#Add environment
viz.addChild('gallery.osgb')
# Create Inertial Labs extension
InertialLabs = viz.add('InertialLabs.dle')
# Connect to sensor on port 5
sensor = InertialLabs.addOSv3(5)
def updateView():
    #pos = sensor.getPosition()
    euler = sensor.getEuler()
    #viz.MainView.setPosition([pos[0], pos[1]+1.82, pos[2]])
    viz.MainView.setEuler(euler)
    print euler
vizact.ontimer(0,updateView)
headtracking
Creating a Vizard Sensor Plugin farshizzo Plug-in development 25 08-01-2019 12:24 AM
Unusual tracker sensor setup with Vizard Zhi Vizard 2 06-12-2012 09:52 AM
sensor or not sensor? nige777 Vizard 0 03-29-2011 04:03 AM
wiimote and sensor bar masaki Vizard 1 03-06-2008 03:07 PM
Multiple Copies of same sensor plugin RedSpikeyThing Plug-in development 2 02-12-2008 02:10 PM
