Old 06-05-2012, 03:57 PM
I'm not sure how the zSight sensor calibrates itself. You might need to ask Sensics about this. Either way, you will need to apply a postEuler operator on the view link to align it with your virtual north. Example:
view_link = viz.link(tracker, viz.MainView)
view_link.postEuler([45,0,0])
The zSight sensor does not provide position data. So you will need to either link a position tracker to the view or manually control the viz.MainView object yourself. For example, if you need to position the view at [1,2,3], you would use the following code:
viz.MainView.setPosition([1,2,3])
Intermittent orthographic stereo projection problems AySz88 Vizard 10 02-17-2012 12:50 PM
The problem of tracker using via VRPN _kj_ Vizard 2 08-13-2009 12:03 AM
problem in setting the orientation of bones bharatbhushan Vizard 0 06-30-2009 04:30 AM
CAVE PPT Tracker Help with Orientation Inversion on Up and Down shivanangel Vizard 3 03-11-2009 09:14 PM
Can you link the position of a tracker to the orientation of an object? michaelrepucci Vizard 1 09-19-2008 10:23 AM
