Old 05-27-2012, 11:12 PM
goro goro is offline
Applying mask using Stencil Function
Hello Friends!
I am using Stencil Function to apply and remove the masked portion of an object. before applying the mask my objects are looking like this:
The front object is logo2, the back object is logo1 & in between object is named masked & it'll be used for masking.
Simple code for viewing this in your vizard is:
piazza = viz.addChild('piazza.osgb')
logo1 = viz.addChild('logo.ive')
logo1.setPosition(0.3,1,5)
logo2 = viz.addChild('logo.ive')
logo2.setPosition(-0.3,1,3)
mask = viz.addChild('logo.ive')
mask.setPosition(0,1,4)
Now when we apply stencil function with using following code:
viz.setOption('viz.display.stencil',1)
#Clear stencil buffer every frame
viz.MainWindow.setClearMask(viz.GL_STENCIL_BUFFER_BIT,viz.MASK_ADD)
mask.stencilFunc(viz.StencilFunc.RenderMask())
mask.disable([viz.COLOR_WRITE,viz.DEPTH_WRITE])
mask.enable(viz.CULL_FACE)
mask.drawOrder(-1)
logo1.stencilFunc(viz.StencilFunc.RenderOutsideMask())
logo1.clipPlane([0,0,1,-2])
logo2.stencilFunc(viz.StencilFunc.RenderOutsideMask())
logo2.clipPlane([0,0,1,-2])
We get an output as shown below:
Now here you'll notice that both the front and back objects are affected by mask. What we want is only back object should get affected and not the front one. But the function will be applied on both the objects as they keep on rotating in our application so many times the front object will go back side of the mask and that time the mask has to clip that object.
Wondering if there is any function viz.StencilFunc.RenderBacksideMask() or viz.StencilFunc.RenderBehindMask()!
Can you please suggest me where am I going wrong?
Is there any way to do this by using shaders?
clipping, hiding, mask, stencil
return variable from keypress function starbug Vizard 2 01-07-2010 12:14 PM
Documentating function names aaThomas Vizard 5 05-15-2007 10:50 AM
Do you know how to send a value for 'pool' to the onActionEnd function? ghazanfar Vizard 1 03-22-2007 11:25 AM
timers and director function Jerry Vizard 1 06-22-2006 10:47 AM
