Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 10-25-2011, 01:54 AM
davidrichens davidrichens is offline
Lightmap VRAY
Hello
I have read the Lightmap tutorial on the wiki, and it worked for creating lightmaps for vizard using 3dsmax scanline render setting.
I have created a scene in 3dsmax that uses vray to produce the lighting. I was wondering how I go about baking lightmap using vray?
When I follow the wiki lightmap tutorial, max crashes! Both 32 and 64 bit version.
When I tried to render a lightmap using VrayLightingMap element in the baking dropdown menu. (See screenshot)
It did render successfully, but it appeared to render something that resembles a complete map! (See screenshot)
When I created a standard material, with a diffuse and lightmap (both rendered using steps above) it created a model with a dark texture that wasn't the same when I rendered in viewport. (I have also attached this OSGB file)
Is there a process that was followed to render lightmap in vray for the dojo/piazza in Viz4?
Thanks!
David
ID:	448   Click image for larger version
lightbaking, vray
VRay, and Complete Character animation questions Lithium Vizard 1 07-27-2011 12:21 PM
How to convert VRay material into Vizard? hengshan.li Vizard 4 01-18-2011 09:14 AM
