your code seems correct. language vizard uses is python you can work with that like c#
define classes will make things clearer most of the time. class something(object): also you could use if a == 'a' and b == 'b': and elif instead of else: if: I replaced your door opening code with a print print "print this string" and I got the correct results so maybe check if your tabs are placed correctly for all the if statements. |
Mouse bug in V3 and V4 | Renato Lima | Vizard | 2 | 05-11-2011 06:38 PM |
Mouse event: how to detect no mouse move event, how to set mouse position? | Zhi | Vizard | 3 | 04-11-2011 06:25 PM |
Warning mouse() -> Set mouse() of window | johannes2 | Vizard | 1 | 08-19-2010 02:11 PM |
Navigating an avatar using mouse position(2D) in 3D environment | james007 | Vizard | 1 | 10-16-2009 11:29 AM |
