Make sure you have full administrator rights on that machine. Being logged in as admin is not always enough. You must also launch Vizard with "Run as admin" method and then run the target script using the parallel port. "Run as admin" done once should be enough and not then required on subsequent executions.
Running as admin should not be necessary for Vizard 4 |
| Question about serial port | mizutani_jun | Plug-in development | 6 | 11-21-2010 04:53 PM |
| Biopac Parallel Port Writer Error: missing INPOUT32.dll | mmatlock | Vizard | 1 | 06-30-2010 03:04 PM |
| parallel port method | bionic1 | Vizard | 2 | 05-04-2009 07:41 PM |
| Best TV out for laptop | Matt Wheeler | Vizard | 0 | 11-10-2008 08:52 PM |
| USB port monitoring | wolbers | Vizard | 1 | 11-20-2007 10:24 AM |
