Old 02-25-2011, 01:32 PM
miles miles is offline
Scaling movement through the virtual environment
I am working on an experiment that requires relative motion through the environment to change under different conditions. However, it seems that when I try scaling the motion, it messes up rotation. When I turn to a certain point, it moves back several degrees. Also, when I set the scaling higher, forward motion is noticeably offset.
This is what I'm using to change the relative motion:
self.link.postScale([self.walkSensitivity,1,self.walkSensitivity],viz.LINK_POS_OP)
There are several other operations being applied on self.link, but the problem only seems to occur when this line is in place.
Any suggestions are appreciated.
miles.
Real environment with virtual objects do interact CRI Vizard 4 05-27-2010 01:05 PM
Open Position: Virtual Environment Programmer aarset Announcements 0 05-31-2009 08:23 AM
Question about input from virtual keyboard. yyang Vizard 4 12-23-2008 01:25 PM
Getting a mirror to work in any environment Frank Verberne Vizard 5 03-27-2008 09:21 AM
Human FOV and VIrtual FOV giancamati Vizard 0 12-14-2006 04:33 AM
