Old 02-13-2011, 08:35 PM
dcnieho dcnieho is offline
noob questions: scene lighting, viewpoint updates
Dear Worldviz,
So I've managed to work with the _SECURE_SCL issue I talked about in the other thread, things are working well now - interface development was pretty easy! Overall, I'm very happy with the speed with which I could develop using Vizard (note: this is my first time touching it). Thanks for the great work, it is indeed obvious you guys work with your own product all the time!
Two noob questions:
1) from my openGL code, I am drawing spheres using gluSphere. The colors don't come out right, they seem to be too dim (while the colors of, for instance, a GL_POINT vertex is fine). I have already put viz.MainView.getHeadLight().disable()
viz.MainScene.disable(viz.LIGHTING)
in my script, but this does not seem to fix the issue. Is there any other lighting / color processing turned on by default that I should look at?
2) In my code, I'll need to compute the instantaneous velocity (either delta (X,Y,Z) or a velocity vector expressed in spherical coorinates (azimuth,elevation,speed) would be fine) and rotation rate (yaw only for now). Are there some built-in functions for this or should I simply save the previous position and orientation and compute these myself?
Thank you for the pointers!
Best,
Dee
Lighting for a new Scene jassel41 Vizard 2 11-10-2010 10:14 PM
Copying Scene? Brett Lindberg Vizard 0 08-29-2009 12:56 AM
