Old 01-31-2005, 12:56 PM
Immediately after you add the tracker try issuing the following command:
myTracker.command(6,'',1,1,1)
This should take care of the problem of placing you above the room. Also, try issuing the following command to scale the ppt movement by 2. This might make the movement more noticeable:
myTracker.command(3,'',2,1,2)
If this still doesn't work, make sure the ppt is connected and that it is sending data. Also, check if Vizard prints out any errors about connecting to the ppt.
