Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Old 11-05-2010, 09:25 AM
nige777 nige777 is offline
Question GEODE Names
Ok so I'm getting myself al tied in knots here
I'm trying to extract the GEODE name (as assigned in max) from all the nodes in an IVE file and reassign them them back to the objects so I can access them through viz.pick(1) like this:
#Fill components list with model child nodes and then sort it
components = model.getNodeNames()
#components.sort
print components #DEBUG
#Traverse through scene graph children one by one and assign Node Names to respective child nodes
for a in range(len(components)):
	if components[a] == "__VIZARD_NODE__": #Ignore root node
		break
		model.getChild(components[a]) == components[a]
Firstly I get a load of warnings like this:
** ERROR: Could not find child with name 'Ceiling Tile 600 x 600'
** ERROR: Could not find child with name 'Concrete - Cast In Situ'
** ERROR: Could not find child with name 'Concrete - Cast-in-Place Concrete'
(which I presume is because Vizard is trying to find child nodes which are in fact materials??)
Secondly all I get returned from the pick routine is the lowest transform on the Node, which in most cases is the material. I've poured over the forum and the help manual but after two days trying to sort this I've only succeeded in tying myself up in knots
Confusingly (for me!) this technique worked with an OBJ file from sketchup but the files I need to work with are Revit files I'm bringing in through Max (as fbx to IVE) -
Could someone please help me out of my friday night hole and suggest a way of achieving this - Thanks
Documentating function names aaThomas Vizard 5 05-15-2007 10:50 AM
changing the texture of an avatars shirt/body bailenson Vizard 19 05-04-2006 11:00 AM
