Old 11-04-2010, 10:20 AM
mkmatlock mkmatlock is offline
Strange Ball Joint behaviour
I am using a ball joint to simulate a long chain with a heavy load attached, swinging from a ceiling.
The user can move this chain up and down using an instrument panel, and the ball joint is used to simulate the slow sway of the load as it is moved. To add a bit of perturbation, I generate a small force in a random direction (parallel to ground plane), and apply it to the load.
However, the load tends to stop swinging in midair, sometimes at quite unrealistic, obvious, and comical angles.
I am using a ball joint attached to the world, and to a long chain object, with a limit on swing of 20 degrees on all axes.
I am worried that one of the reasons the ball joint is not functioning correctly is that, in order to move the load up and down when the user uses the control panel, I have to detach the chain from the ball joint, move the chain, then reattach it. Perhaps there is a better way to do this? Calling 'move' without detaching the load doesn't allow it to move beyond a very small amount.
moving and object by mouse but don't know how to stop the movement nlfrnassimi Vizard 8 04-26-2009 07:23 AM
how can I stop an action? nlfrnassimi Vizard 4 02-13-2009 12:59 AM
Strange Rendering Lag Spikes theuberk Vizard 3 02-26-2008 09:55 AM
Tk with Vizard abnormal behaviour Gilliard Vizard 2 08-04-2005 01:14 AM
