Old 09-06-2010, 04:19 PM
Dave Dave is offline
Collision problem
Hi - I am having trouble with viewpoint collision. I have a very large mesh that is a landscape and in a few places I have smaller separate models overlying the mesh that are more detailed areas.
The viewpoint flies over the landscape and is prevented from descending below a fixed level except when it is above the more detailed models where I would like it to go lower but collide with the ground and not go through it.
<viewpoint>.collision( viz.ON ) does actually work but the problem is that the 'flythrough' judders to a crawl - presumably because the viewpoint needs to check whether it is going to collide with every node in the large landscape.
I had hoped that collideMesh applied to the smaller models would cause the viewpoint to collide just with those models but try as I might I cannot get the viewpoint to collide with anything in this way.
I presume that collideMesh, collideBox etc only operate between objects and not a viewpoint and an object. Is there any way to make the viewpoint collide with the surface of a single object within a scene?
Any ideas will be very much appreciated.
Dave
problem with collision? shahramy Vizard 1 06-01-2010 01:17 PM
problem with collision ruby21 Vizard 3 05-19-2010 05:32 PM
Collision problem: Balls fly through the wall Chrissy2009 Vizard 11 05-19-2009 04:38 AM
Collision with child nodes rubberpimple Vizard 4 09-17-2008 04:27 PM
problem with collision detection paulpars Vizard 6 06-09-2006 06:03 PM
