Old 07-26-2010, 01:12 PM
Hi shahramy
-One common method is to use fog + distance culling.
-Another option is to use the OSG Level of Detail helper. With this one, you would merge or group all the objects in a room and add it to the LOD helper, then set the distance in meters for that object to be visible. You can set up objects to simply disappear after a certain distance, or you can switch in lower detail versions of the object. These have to be created manually.(Helpers --> OpenSceneGraph --> LOD)
-Vizard does not currently have a way of automatically doing occlusion culling,
but Occluders can be added manually within 3ds max using rectangular splines and the OSG Occluder helper. (Helpers --> OpenSceneGraph --> Occluder)
Level of Detail envisC Vizard 2 10-22-2009 01:07 PM
Strange Rendering Lag Spikes theuberk Vizard 3 02-26-2008 10:55 AM
Any way to increase rendering resolution v-Salik Vizard 3 09-12-2007 05:57 PM
Buttons Not rendering to both Eyes in 3d shivanangel Vizard 2 05-24-2007 07:58 AM
Texture map rendering problem JRichizzle Vizard 4 03-04-2004 08:20 AM
