Old 06-30-2010, 08:05 AM
VelvetElvis VelvetElvis is offline
You can actually skip motion builder all together. You can load the .bvh file or other motion capture format directly onto the biped in Max.
You can load all of your animations in one sequence or sequence them out and control which ones are loaded in what order in the cfg file in Vizard.
Granted, it would be much easier if Vizard supported animated bipeds directly (ie reading the .bip file and translating that onto the bones as it does in Max) or could read the point cache files (either in xml or pc2 format) created in Max, but that would be too simple.
Motion Capture & CyberGloves EnvisMJ Vizard 1 10-01-2009 04:21 PM
screen capture from all cluster computers? dtidrow Vizard 1 09-16-2009 10:25 AM
Motion Capture Props staircaseduets Vizard 1 07-09-2009 12:56 PM
Eliminate Sideways Motion when colliding w/Objects Feuereissen Vizard 3 07-09-2009 12:43 PM
Vizard Enterprise Edition and motion capture aaThomas Vizard 4 10-05-2007 10:31 AM
