				Animated Splashscreen
			I have a custom splashscreen image for my application.  I would like to have it animated much like the default Vizard splashscreen.  That way people know that their computer hasn't locked up while the program is loading. I guess I should ask first, is this even possible? I tried an animated gif for the image, but that just shows a single frame of the gif. Any help would be appreciated. Thanks. Aaron |
			i have interest in this too, i would like to know if is possible to have a animated splashscreen
			It turns out that no, you currently can't have an animated splashscreen, but I have put in a feature request to WorldViz.  We'll see if it happens or not.  If more people request it, it could increase the chances that it will happen. Aaron |
			Oh well, i hope they develop this feature, just a question where i can put a feature quest?
			As far as I know an animated splash screen does not exist in Vizard. I used the AdvancedSplash, based on wxpython. You can send me a PM for setup code. As a side note, if you want to avoid long loading screens, there is nothing wrong with calling viz.go() after initializing and loading the world and textures ect. |
			You can use the built-in HTML feature of Vizard to create custom HTML based splash screens. Here is a simple example: Code: import viz
# Display HTML over entire window
viz.window.displayHTML('http://www.youtube.com/watch?v=a1Y73sPHKxw&autoplay=1',pos=(0,0),size=viz.window.getSize())
# Hide HTML at beginning of first frame
vizact.ontimer2(0,0,viz.window.hideHTML)
Load script
viz.waittime(8.0) # Simulate long load time  |
|  Similar Threads | ||||
| How do we create cfg, vzf and ive files | luakt | Vizard | 14 | 07-17-2009 01:45 PM |
| Freeform view on an animated object problem | jaylocco | Vizard | 2 | 06-08-2009 08:09 PM |
| move animated camera around corner question | nlfrnassimi | Vizard | 1 | 02-23-2009 09:45 AM |
| Software to create animated characters | luakt | Vizard | 3 | 09-14-2008 11:01 PM |
| animated gifs | jrodman | Vizard | 1 | 03-16-2004 09:48 AM |
