Old 03-26-2010, 09:35 AM
Moh200jo Moh200jo is offline
Draw Line
I am trying to create lines between points moving through x to y. I created the line but these lines appear in different positions (according to the points). Is there any way to draw just a solid line between 2 points and moved with them?
viz.startlayer(viz.LINE_STRIP)
	viz.vertexcolor(0, .6, 0)
	viz.vertex(point1)
	viz.vertex(point2)
	line1-2 = viz.endlayer()
How can I present the real time value of the point on the Vizard?
Any suggestions?
Old 03-26-2010, 09:58 AM
Darkmax Darkmax is offline
I think you have to use the method setVertex for the line that you created
this code is a example of a line that moves in X
viz.vertexcolor(0, 0.6, 0)
#This is vertex 0
viz.vertex([0,0,0])
#This is vertex 1
viz.vertex([1,1,0])
line = viz.endlayer()
x=0
def moveLine():
	global x
	line.setVertex(0,[0+x,0,0])#setVertex(vertex id,[x,y,z])
	line.setVertex(1,[1+x,1,0])
	x = x+1
vizact.ontimer(1,moveLine)
Old 03-29-2010, 08:42 AM
Darkmax,
Many thanks for your post
I have done it, but my problem is to keep the lines between the points in the mainview.
I used postMultLinkable function to make sure my points (that I reading from real-time) are in the mainview, this worked lovely with the points but the lines between these points left the points once I move the mainview.
Is there any advices can be provided?
Old 05-05-2010, 05:40 AM
How can I draw cylinder between 2 points by using viz.vertx?
how to invoke command line question billjarrold Vizard 2 01-11-2010 08:51 AM
Draw line and rotate it Chrissy2009 Vizard 5 09-07-2009 01:10 AM
Draw line with a triangle at the end Chrissy2009 Vizard 9 08-24-2009 11:12 AM
Draw Line between Points Chrissy2009 Vizard 2 05-13-2009 04:42 AM
Draw Line between Points selected by mouse Johannes Vizard 7 01-07-2005 02:50 PM
