Old 03-27-2010, 04:15 AM
moneim230 moneim230 is offline
G25 steering wheel range !
Hello all,
I'm using the G25 steering wheel which has 900 degrees steering range (450 to the right and 450 to the left).
I use vizjoy.getPosition() to get the value of steering, the value comes on X.
The problem is that i get "-1" for 90 degrees to the left and "1" for 90 degrees to the right, I need to get the full range (900 degrees). How can i scale it ??
Old 03-28-2010, 07:04 AM
dwaik dwaik is offline
here you dont want to scale first, you need to get the full range [-5,5] if you can get it,
then you can use the mathmatical range scaling which:
to scale x form range [a-b] to range [c-d]
newX=(x-a)/(b-a) #here you will have your value in range [0-1]
finalValue=(newX*(d-c))+c #and here you will have your value in range [c-d]
which in your case if x was 2 in range [-5,5] and you need to change it to range [-450,450]
you can solve it as follows:
newX=(2-(-5))/(5-(-5)) #7/10=0.7 in range [0,1]
finalValue=(0.7*(450-(-450)))+(-450) #(0.7*900)-450=180 and thats it
hope that helps
Old 03-28-2010, 04:54 PM
hope that helps
unfortunately it didn't work.....the G25 has 900 degrees of rotation, when running games, you can freely steer it through the whole 900 degrees, but in Vizard it is freely to steer it only to +90 or -90, outside this range the wheel feedback works (you can continue steering but you'll feel a force in the opp. direction + nothing happens in vizard after steering more than 90).
therefore, in the scaling equation you wrote, finalValue is 90 max when steering right and -90 for steering left
thank you for your help
Range of Cameras Vic Precision Position Tracker (PPT) 2 06-11-2009 07:19 AM
How to get the data from Logitech G25 racing wheel ? fuyonggang Vizard 4 12-18-2008 07:14 PM
Flock of birds extended range problem theuberk Vizard 4 07-30-2007 10:31 AM
Do you have some idea about the bicycle and wheel sled Vizard 6 08-01-2003 11:03 PM
Can I see infinite distance sled Vizard 2 07-16-2003 05:18 PM
