Old 03-11-2010, 05:38 PM
hahaho hahaho is offline
using sensor.
Hi worldviz
i want to use sensor of three.
so, i make a code following.
vrpn = viz.add('vrpn7.dle')
tracker1 = vrpn.addTracker('PPT0@166.104.29.228',0)
tracker2 = vrpn.addTracker('PPT0@166.104.29.228',1)
tracker3 = vrpn.addTracker('PPT0@166.104.29.228',2)
def update():
position1 = tracker1.getPosition()
position2 = tracker2.getPosition()
position3 = tracker3.getPosition()
a = position1[0]
a1 = position1[1]
a2 = position1[2]
#print a1
b = position2[0]
b1 = position2[1]
b2 = position2[2]
print b1
c = position3[0]
c1 = position3[1]
c2 = position3[2]
#print c1
vizact.ontimer(0,update)
but !! the location of sensor is frequently change.
How can i ??
Old 03-12-2010, 10:03 AM
Sorry, I don't understand the question.
Please use code tags when posting code to preserve indentation
Old 03-12-2010, 08:23 PM
Arrow
ok.
I want to use the sensor of the three.
these sensors want to fixed number[A,B,C], (no value[x,y,z])
for example)
sensorA(fixed number) = (10,10,10) <-x,y,z (receive(change) value)
sensorB(fixed number) = (20,20,20) <-x,y,z (receive(change) value)
sensorC(fixed number) = (30,30,30) <-x,y,z (receive(change) value)
so, i am used this code.
sensorA = vrpn.addTracker('PPT0@166.104.29.228',0)
sensorB = vrpn.addTracker('PPT0@166.104.29.228',1)
sensorC = vrpn.addTracker('PPT0@166.104.29.228',2)
def update():
      position1 = sensorA.getPosition()
      position2 = sensorB.getPosition()
      position3 = sensorC.getPosition()
      a =  position1[0]
      a1 = position1[1]
      a2 = position1[2]
      b = position2[0]
      b1 = position2[1]
      b2 = position2[2]
      c = position3[0]
      c1 = position3[1]
      c2 = position3[2]
      A = [a,0,a2]
      B = [b,0,b2]
      C = [c,0,c2]
      # vector
      v1 = vizmat.VectorToPoint(A,B)
      v2 = vizmat.VectorToPoint(A,C)
      v = vizmat.AngleBetweenVector(v1,v2)
      Forearm.setEuler([0,0,-v])
      UpperArm.setEuler([0, -30, -80])
      print v
but , the sensor's number is frequently change.
for example)
sensorB = (10,10,10)
sensorA = (20,20,20)
sensorC = (30,30,30)
sensorC = (10,10,10)
sensorB = (30,30,30)
How do i receive the fixed sensor's number?
Creating a Vizard Sensor Plugin farshizzo Plug-in development 25 08-01-2019 12:24 AM
Sensor gets confused durf Precision Position Tracker (PPT) 1 04-23-2009 12:41 PM
wiimote and sensor bar masaki Vizard 1 03-06-2008 03:07 PM
Multiple Copies of same sensor plugin RedSpikeyThing Plug-in development 2 02-12-2008 02:10 PM
using sensor data in Physics1.py Eunice Vizard 4 01-03-2006 05:18 AM
