Old 01-05-2010, 08:53 AM
Moh200jo Moh200jo is offline
Tasks
I am using collision detection between Box1 and Box2 to count ball lob in a game. I am struggling to calculate balls number depends on this specific collision. I know I have to use function of the collision to do so.
I do not know how I can send information to the task1 from collision function to start add 1 to ball, the code I am using to do so as follows:
To detect the collision between Box1 and Box2 I am using the following code:
def onCollideBegin(e):
	if e.obj1 == box1 and  e.obj2== box2:
                      print e.obj1 , “    ,” , e.obj2
viz.callback(viz.COLLIDE_BEGIN_EVENT,onCollideBegin)
if collision happened I have to add 1 to ball
ball=0
def task1():
global ball
	while ball <4:
		yield viztask.waitEvent(viz.COLLIDE_BEGIN_EVENT)
		ball +=1
		print 'Number of Balls is : ',sball
In else where in the game function I am using the following line, the game function will quit the game if ball number is 4
balllob = viztask.waitTask( task1())
I guess I have to use the detection function, but I do not know how can I use it with many tasks relating to each other , as far as I realized Vizard’s documentation also dos not have this.
Old 01-05-2010, 06:11 PM
You could try creating your own custom event that gets generated whenever certain objects collide. Then in your task function wait for that custom event and increment your counter after that occurs.
Old 01-07-2010, 09:59 AM
Thanks for this, and it is understood
I tried to do the following but still incorrect
                      action=vizact.call( task1())
ball=0
def task1():
global ball
	while ball <4:
		yield viztask.waitEvent(action)
		ball +=1
		print 'Number of Balls is : ',ball
My problem I do not understand how can connect these functions
Any help?
Old 01-08-2010, 04:34 AM
I have tried to use box1.collidingwith(box2) but this made the game meet the condition once I run the code
 ball=0
def task1():
global ball
	while ball <4:
		action=box1.collidingwith(box2)
		ball +=1
Old 01-08-2010, 08:48 AM
There a few ways you could do this. You could use viztask's signal and wait functions and send a signal when the collision of those objects occurs within your onCollideBegin function. Then wait for that signal in your task function.
Or you could create a custom event that is generated when those two objects collide and wait for that event in your task function. The docs describe how to create a custom event.
Old 01-08-2010, 11:53 AM
Well, what is I can not do it in Vizard to send a signal from the function to the task.
may you can gipost an example of this (sending a signal from a fuction to a task)? I do not find any on the documentation
Old 01-08-2010, 02:41 PM
Take a look toward the bottom of the following page. There is an example there for using signalling with tasks.
http://www.worldviz.com/vizhelp/VizTask_basics.htm
Tasks Moh200jo Vizard 1 02-23-2009 10:57 AM
Vizard Tip of the Month: Use Tasks to Simplify your Code Gladsomebeast Vizard 5 05-02-2008 04:30 PM
