Old 09-04-2009, 09:28 AM
vijaykiran vijaykiran is offline
Tiling in a cluster setting
I looked at setting up a cluster for multiple walls with one instance of Vizard running on each wall here (http://www.worldviz.com/vizhelp/Conf...ur_cluster.htm). I was wondering what needs to be done for running multiple instances of Vizard tiled together on a single wall.
I was wondering if there is any documentation on doing this.
Each of our projectors have four video inputs, so four instances of Vizard will need to be tiled and stitched together. Any assistance would be greatly helpful.
Vijay.
Old 09-04-2009, 04:37 PM
Have a look at the documentation for the vizcave module. The cave.addWall command accepts a mask parameter that controls which computer in the cluster will render that wall. So split up your physical wall into 4 quadrants and create a virtual wall for each quadrant.
Old 10-28-2009, 03:00 PM
dtidrow dtidrow is offline
CAVE with tiled walls?
Can you create a CAVE with multiple projectors per wall? For example, we're looking into creating a CAVE with three walls and a floor, each surface consisting of four projectors driven by at least two computers (ideally one-to-one). How would you set this up in Vizard? Could you also overlap the projectors so that they can edge-blend?
Old 10-29-2009, 12:24 PM
Yes, this should be possible with the vizcave module. A vizcave.Wall object does not necessarily have to represent an actual physical wall. It simply represents the physical rectangular surface that the computer is responsible for rendering to.
The vizcave module does not perform edge-blending. This is usually left to the hardware to accomplish. However, you can specify overlapping dimensions for the wall objects.
Old 10-30-2009, 11:32 AM
Okay, that's pretty much what I thought. So is there any upper limit to the number of PC's you can have in a cluster? Is there a degredadion in performance as you add more PC's to the cluster? Would it be beneficial to have a master computer only control the slaves, and have the slaves do all the rendering?
Old 10-30-2009, 11:41 AM
Currently, you can have a maximum of 32 computers in a cluster.
Having more computers means more network traffic, so there might be a small performance hit in that regard.
Having the clients perform all the rendering is perfectly fine. Simply add the following code to your script to prevent the master from rendering:
viz.cluster.pushMask(viz.MASTER)
viz.MainWindow.visible(0)
viz.cluster.popMask()
Lighting on a 3 channel cluster ajmurray Vizard 3 10-10-2007 09:57 AM
Cluster Help videcuk Vizard 12 09-21-2007 02:14 PM
Material Tiling Vinicius Lima Vizard 1 08-08-2007 11:17 AM
Cluster problems for RC1 hotspur1 Vizard 1 04-04-2007 12:31 PM
quad_buffer cluster John P Vizard 4 06-07-2006 10:01 PM
