Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 10-23-2009, 01:27 PM
sircedric4 sircedric4 is offline
Array, concatenate, multiple path help please
Maybe I'm thick, but I am still learning Python. I am trying to setup multiple paths for different models that I am incorporating into my program. In the past I was doing this the clunky way by introducing a separate variable for each path:
Example:
path1 = viz.add(viz.ANIMATION_PATH) )
path2= viz.add(viz.ANIMATION_PATH) )
path3 = viz.add(viz.ANIMATION_PATH) )
etc...
Then when I wanted to adjust it I would do things like:
path1.speed(1)
path1.loop(viz.CIRCULAR)
path2.speed(1)
path2.loop(viz.CIRCULAR)
path3.speed(1)
path3.loop(viz.CIRCULAR)
Needless to say this in very clunky, and I want to setup a more default program that doesn't have each path spelled out since I won't always know how many paths I am playing with. I am sure there is some way to do this with for (do-loop) statements.
I guess I don't understand why I can't seem to use an array to do this job. I've tried path[0], path[1], etc... but when I goto tweak the path[0].speed it says no such attribute exists. I believe this is because arrays can't be set to do viz.adds or something. I think arrays can only be certain types and what I am trying to do doesn't fall under that type.
Is there a way to concatenate strings in python? (I come from VB where there is that capability) So for example I could
path + 'someinteger' = viz.add(viz.ANIMATION_PATH) )
and then use that same left hand side wherever to change things
(path + 'someinteger' ).speed(1)
I've tried searching for the means to do this all over the internet and I am hoping someone more familiar with python can tell me the easiest way to do what I am trying to do. I just want variables that I can adjust with a do-loop without having to manually add a bunch of numbered variables. This simple capability is really holding me back on several programs, help please.
Old 10-25-2009, 06:30 AM
IGoudt IGoudt is offline
I would do the following using a list, so that path1 is on index 0 and path n on index n-1
pathlist = list()
for curNumber in range(maxNumberOfPaths) :
     path = viz.add(viz.ANIMATION_PATH)
     path.speed(1)
     path.loop(viz.CIRCULAR)
     pathlist.append(path)
The way to concatenate strings in Python is:
'text' + str(otherArgs)',
so 'path' + str(1) would become 'path1'
If you are unsure about the ability of the otherArgs to be casted correctly, you can wrap a try/catch around it.
If you want to call elements in a container by their name, you can use a dictionary.
Old 10-26-2009, 03:48 AM
I forgot to mention that you cannot use operators and functions on the left side of the equals sign.
path + 'someinteger' = viz.add(viz.ANIMATION_PATH) would not work, but
pathDictionary[path + str(someinteger)] = viz.add(viz.ANIMATION_PATH) will.
Old 10-28-2009, 06:14 AM
Thanks, the List() thing is what I was missing. I used the basics of what you outlined and got the program to do exactly what I was looking for.
I kept looking for arrays in the python manual and all it kept showing me was dictionary stuff and it wouldn't do what I wanted. I figured someone more familiar with python would be able to point me directly to what I wanted.
Thanks again.
smoothing a cubic bezier path just alex Vizard 10 04-22-2009 02:07 PM
2D or 3D array help? durf Vizard 1 02-20-2009 11:57 AM
Problems with interaction of vizact.turn and animation path Enlil Vizard 3 11-24-2008 05:23 PM
speed on animation path whj Vizard 8 11-17-2008 08:41 PM
Copy objects in an array to another array Johannes Vizard 3 04-29-2005 03:37 PM
