Old 09-23-2009, 09:33 AM
Jerry Jerry is offline
Is Vizard compatible with Vista 64-bit?
I am planning to purchase a new computer to be used with Vizard.
Is there any reason not to choose Vista Home Premium 64-bit OS?
Old 09-23-2009, 09:37 AM
Yes, Vizard will run on Windows Vista/7 64-bit. Keep in mind that Vizard is still a 32-bit application, so it won't be able to take advantage of 64-bit hardware (i.e. use more than 4 GB of memory). Also, if you are using any hardware devices with Vizard you will need to use the 64-bit version of the device drivers.
Old 09-23-2009, 10:53 AM
Works just fine on 64 bit vista. I run it all the time.
Vizard on Vista try. krimble Vizard 1 04-15-2008 07:44 PM
Peripherals compatible with Vizard Vinicius Lima Vizard 3 03-05-2008 10:44 AM
