Old 09-15-2009, 07:40 PM
omidbrb omidbrb is offline
window.pick function over sub-window
I have a function that examines all the pixels of the MainWindow using the window.pick function. The problem is that when I use a sub-window instead of MainWindow, I get strange results. Specially, the window.pick command returns "no object" over the portion of the MainWindow that hasn't been occupied by the sub-window. My question is, does the window.pick function works with sub-windows?
Best,
Omid
Old 09-17-2009, 10:50 AM
The window.pick function only works for that window. You will have to call the pick function for the specific window you are interested in. You can use the viz.window.select command to get the current sub-window located at the specified screen position. I just noticed that this command is currently undocumented, so here is some example code showing how to use it:
# Get the sub-window located at the current mouse position
window = viz.window.select()
# Get the window located at the center of the screen
window = viz.window.select([0.5,0.5])
# Get the window located at pixel location (100,100)
window = viz.window.select([100,100],mode=viz.WINDOW_PIXELS)
Old 09-23-2009, 06:38 AM
I think I didn't describe the problem clearly. Imagine I created a window:
	UpperRightWindow = viz.addWindow()
	UpperRightWindow.position (0.6, 1.0)
	UpperRightWindow.size(0.4, 0.4)
	UpperRightWindow.visible(0,viz.SCREEN)
	RightEye = viz.add(viz.VIEWPOINT)
	RightEye.eyeheight(0)
	rightLink = viz.link(avatar.getBone('Bip01 Head'),RightEye)
	UpperRightWindow.viewpoint(RightEye)
	UpperRightWindow.clip(0.00001, 50000)
Then I want to determine what object lies at any pixel:
	xres = 200
	yres = 200
	size = (xres, yres)
	for x in xrange(xres):
		for y in xrange(yres):
			xNorm = x/(xres*1.0)
			yNorm = 1-y/(yres*1.0)
			intersect = UpperRightWindow.pick(True, viz.WORLD, pos = [xNorm, yNorm])
			if intersect.valid == True:
				print "pixel " + str(x) + "," + str(y) + "," + intersect.name + "," + str(intersect.point)
				print "no object at " + str(x) + "," + str(y)
This function works correctly with viz.MainWindow but not with the new UpperRightWindow.
Am I doing anything wrong?
Best,
Omid
Old 09-24-2009, 12:55 PM
Are the coordinates you are passing to the pick function relative to the lower-left corner of the sub-window, or the lower-left corner of the graphics window? The pick function expects coordinates that are relative to the lower-left corner of the graphics window. Here is a simple script showing that picking does work with sub-windows:
viz.mouse(0)
viz.clearcolor(viz.GRAY)
#Add sub-windows
window = viz.addWindow(view=viz.addView(scene=2),pos=(0.8,1))
window = viz.addWindow(view=viz.addView(scene=3),pos=(0,1))
window = viz.addWindow(view=viz.addView(scene=4),pos=(0,0.2))
window = viz.addWindow(view=viz.addView(scene=5),pos=(0.8,0.2))
#Add quad to each window
viz.addTexQuad(pos=(0,1.8,2),color=viz.WHITE,scene=1)
viz.addTexQuad(pos=(0,1.8,2),color=viz.RED,scene=2)
viz.addTexQuad(pos=(0,1.8,2),color=viz.GREEN,scene=3)
viz.addTexQuad(pos=(0,1.8,2),color=viz.BLUE,scene=4)
viz.addTexQuad(pos=(0,1.8,2),color=viz.YELLOW,scene=5)
def dopick():
	win = viz.window.select()
	if win:
		node = win.pick()
		if node:
			node.runAction(vizact.sizeTo(size=[2,2,1],time=0.1))
			node.addAction(vizact.sizeTo(size=[1,1,1],time=0.1))
vizact.onmousedown(viz.MOUSEBUTTON_LEFT,dopick)
Old 10-02-2009, 04:23 AM
Thanks. Yes the problem was relativity to the graphics window.
Documentating function names aaThomas Vizard 5 05-15-2007 09:50 AM
Do you know how to send a value for 'pool' to the onActionEnd function? ghazanfar Vizard 1 03-22-2007 10:25 AM
timers and director function Jerry Vizard 1 06-22-2006 09:47 AM
node3d.center function tavaksai Vizard 3 08-13-2004 11:05 AM
The error window that couldn't FlyingWren Vizard 2 12-02-2003 08:23 AM
