Old 08-19-2009, 06:17 PM
GiudiceLab GiudiceLab is offline
Attaching sound to a moving object
I am working on figuring out the more complex sound properties and functions in pySonic. I am trying to get a helicopter-style test script to work (where the sound source circles the listener). I can have a sound play successfully if I move the object--a duck--or if I move the viewpoint relative to the duck, but if I use this code:
duck.center(0,0,radius)
duck.translate(0,0,-radius)
duck.addAction(vizact.spin(0,1,0,45))
#duck.playsound('quack.wav',viz.LOOP)
sound.LoopMode = pySonic.Constants.FSOUND_LOOP_NORMAL
sound.Play()
the duck will circle, but the sound source won't follow it like it does if I use viz's playsound function.
If I output the duck's position, it does not change, so this is really why the sound doesn't update. So I guess my real question is, how do I get the duck's position during this action?
Virtual Environments and Multimodal Interaction (VEMI) Lab
This time, it should work...
Old 08-19-2009, 06:21 PM
How are you retrieving the duck's position? The following code should work in your case:
duck.getPosition(viz.ABS_GLOBAL)
Old 08-20-2009, 08:11 AM
That seems to have done the trick, thanks. I was using just
duck.getPosition()
I guess the default is viz.ABS_PARENT, but I don't understand why it works when the object is not in motion.
Old 08-20-2009, 10:41 AM
It had nothing to do with the object being in motion. It had to do with the use of the node.center command. Changing the center and spinning the object will affect it's global position, but it's local position is still where you initialized it to (0,0,-radius).
Old 08-20-2009, 01:18 PM
I see. That makes sense. Another thing I can't figure out, though: the duck circles but at an angle, so it dips below the floor halfway around and then comes back up. Any ideas on why that's happening?
Old 08-20-2009, 01:55 PM
Can you post a simple script that recreates this? It sounds like you might be modifying the pitch of the duck or your ground plane is not level.
Old 08-21-2009, 09:52 AM
Tilted duck...
Aha! I figured it out when I was creating the test script for you--I had the duck looking at [0,0,0], which meant it was tilted. I changed it to the look at the correct height [0,height,0], then centered and translated it at the correct height and that fixed the issue.
Thanks anyway!
moving and object by mouse but don't know how to stop the movement nlfrnassimi Vizard 8 04-26-2009 08:23 AM
Moving avatars lips with sound dan12345 Vizard 5 01-29-2008 08:32 PM
sound problem alaa Vizard 7 09-02-2005 02:13 PM
Moving view with object Xliben Vizard 2 07-25-2005 06:36 PM
