Old 10-03-2004, 06:12 PM
vcarlson vcarlson is offline
Question PROBLEM: Picture-in-Picture breaks textures?!?
I am implementing a picture-in-picture view where the main view is what the user sees and a small windown in the corner shows an outside view of the user's avatar. The apprearence of the outside window is triggered by a keyboard callback like so:
def mykeyboard(button):
  global cheat, PinP # initialized as PinP = viz.add(viz.WINDOW)
  if button is ' ':       #space on keyboard toggles PinP window
    if cheat == 0:
      cheat = 1
      PinP.visible(viz.ON)
      cheat = 0
      PinP.visible(viz.OFF)
The script runs without a problem (the PinP window is invisible at the beginning) undil the spacebar is pressed when all the textures go crazy (smearing, no detail, rectangular surfaces break in to two triangular polys), but textures on avatar faces remain normal!
is there somehting like a viz.REDRAW command, or some other way to solve this problem?
Note: after the textures are broken, toggling the extra window ON and OFF does not fix the texture problem.
Old 10-04-2004, 08:16 AM
tobin tobin is offline
What is your graphics hardware?
Old 10-04-2004, 10:43 AM
vr_boyko vr_boyko is offline
Graphics hardware:
The graphics card is NVIDIA GeForce 6800 GT with freshly installed drivers, but the script does the same running on a GeForce 5900, so I do not think it's the graphics hardware. If needed, I can also send the swole script to you, mybe you'll get a better idea of what is going on with the textures and if the same thing happens on other graphics cards?
Old 10-04-2004, 10:47 AM
Yes, sounds like an interesting bug. Please zip and email the script and supporting files to support@worldviz.com. Thanks.
Old 10-05-2004, 04:22 PM
Problem solved!
I finally figured out the texture problem:
the culprit was in the windown initialization code:
othrPOV = viz.add(viz.VIEWPOINT)
othrPOV.translate(0,0,3.4)
PinP.viewpoint(othrPOV)
I had switched the last two lines , so vizard didn't like hiding a window and changing its viewpoint.
