Old 07-23-2009, 12:57 PM
mjabon mjabon is offline
simple VRPN question
Hello. We have a problem doing the most simple thing with VRPN, which is tracking just one light on the head to move you through the world. In our old code we simply wrote:
viz.go(viz.PROMPT | (viz.HMD + viz.STEREO + viz.TRACKER))
if viz.get(viz.TRACKER):
	PORT_PPT = 1
	viz.cursor(viz.OFF)
	viz.mouse(viz.OFF)
	ppt = viz.add('vizppt.dls')
	#Average over 5 samples
	ppt.command(5,'',5)
	isense = viz.add('intersense.dls')
	viz.tracker()
	#Set eyeheight to zero since we are getting it from the tracker
	viz.eyeheight(1.9)
That is all we had to do.
I tried replacing it with this:
vrpn = viz.add('vrpn7.dle')
ppt = vrpn.addTracker('PPT0@HOSTNAME', 0)
Where hostname is the ip of our PPT machine. However, nothing tracks - ie the person does not move through the world. We don't get errors, the person just does not move.
Any ideas?
Maria
Old 07-23-2009, 04:06 PM
Could you show the code you use to link the VRPN tracker to the viewpoint?
What happens when you just try to print out the data in a timer function?
def showData():
	data = tracker.getData()  # Access the raw data
	print data                # Print the array of data
vizact.ontimer(0, showData)
Old 08-25-2009, 10:12 PM
We get data, it just does not move the person in the world. Does anyone have a simple script they could share that uses VRPN with 1 light on an HMD?
VRPN info sdiverdi Precision Position Tracker (PPT) 5 01-16-2011 12:00 PM
simple question? Boombay Vizard 1 07-06-2009 10:51 AM
swapPos and swapQuat with VRPN michaelrepucci Vizard 1 07-29-2008 11:27 AM
VRPN won't update Wytze Precision Position Tracker (PPT) 7 05-28-2008 07:15 AM
