Old 07-16-2009, 02:28 PM
yak yak is offline
help with slider code
#Initialize avatar
male = viz.add('vcc_male.cfg')
male.setPosition(0,0,5)
male.setEuler(180,0,0)
ANIM = 6
DUR = male.getDuration(ANIM)
#Start animation
male.execute(ANIM)
male.setAnimationSpeed(ANIM,0) #Speed must be set after animation is executed
#Use slider to modify animation time
slider = viz.addSlider(pos=(0.5,0.1,0))
def myslider(pos):
	male.setAnimationTime(ANIM,pos*DUR-0.01)
vizact.onslider(slider,myslider)
[/QUOTE]
This code is helpful but I am stuck on trying to get my avatar to make more actions. how do I get my avatar to jump, in other words more than one action..
Thank you
Old 07-20-2009, 10:47 AM
That example code uses the ANIM variable to control which action of the avatar to play. If you change the value to another animation number, then the slider will control a different animation.
Old 07-20-2009, 01:12 PM
yak yak is offline
I understand that part because I experimented with it..what I want to do is to either have multiple sliders to control different actions or from a push of a button have teh actions automatically change I was thinking of adding an "if" statement to do that but I am still having problems. any suggestions? you have been a great deal of help.
meaning of code yak Vizard 3 07-15-2009 02:18 PM
Any ideas on linking chess 3ds file with source code? djones1010 Vizard 1 04-24-2009 10:56 PM
Trying to integrate Source Code with Vizard djones1010 Vizard 1 03-10-2009 03:58 PM
Vizmenu slider bug? Gladsomebeast Vizard 2 10-22-2008 09:05 PM
Vizard Tip of the Month: Use Tasks to Simplify your Code Gladsomebeast Vizard 5 05-02-2008 05:30 PM
