Old 07-11-2009, 12:27 PM
yak yak is offline
meaning of code
Hi i was wondering what this code means
wheelbarrow = viz.add('vcc_male.cfg')
wheelbarrow.translate(0,1,3)
wheelbarrow.state(2)
wheelbarrow.rotate(0,3,0, -90)
viz.clearcolor(0.5,0.5,1)
def myslider(obj, pos):
wheelbarrow.runAction( vizact.spin(0,-1,0,500*pos) )
viz.callback(viz.SLIDER_EVENT,myslider)
I keep getting my male model to spin while walking. What I am trying to accomplish is that the slider controls my models walk. so if i slide my slider to teh end, my male model has completed one cycle of walking...If i slide it back he is being reversed(kind of like a fastforward and rewind )....I dont know if that made any sense.
Old 07-13-2009, 09:59 AM
That code is adding a spin action to the object when the slider is moved. If you want to move through an avatar animation using the slider, the following code should help:
#Initialize avatar
male = viz.add('vcc_male.cfg')
male.setPosition(0,0,5)
male.setEuler(180,0,0)
ANIM = 6
DUR = male.getDuration(ANIM)
#Start animation
male.execute(ANIM)
male.setAnimationSpeed(ANIM,0) #Speed must be set after animation is executed
#Use slider to modify animation time
slider = viz.addSlider(pos=(0.5,0.1,0))
def myslider(pos):
	male.setAnimationTime(ANIM,pos*DUR-0.01)
vizact.onslider(slider,myslider)
Old 07-13-2009, 01:59 PM
yak yak is offline
#Initialize avatar
ANIM = 6
#Start animation
male.execute(ANIM)
def myslider(pos):
thanks you your teh man!
Old 07-15-2009, 01:18 PM
yak yak is offline
#Initialize avatar
ANIM = 6
#Start animation
male.execute(ANIM)
def myslider(pos):
What if I want to make multiple sliders that control different actions such as walking or jumpin, what should I add in the code?
Example code for VizCave stefs Vizard 6 01-08-2013 11:43 AM
Any ideas on linking chess 3ds file with source code? djones1010 Vizard 1 04-24-2009 09:56 PM
Trying to integrate Source Code with Vizard djones1010 Vizard 1 03-10-2009 02:58 PM
Vizard Tip of the Month: Use Tasks to Simplify your Code Gladsomebeast Vizard 5 05-02-2008 04:30 PM
Vizard Crashes: causes are hard to determine, possible problem with the viz code vr_boyko Vizard 1 01-07-2005 10:52 AM
