Old 06-22-2009, 05:22 AM
Saz Saz is offline
changing the gain of a joystick during a program
I want to change the gain of the joystick by altering the scalar constant (in this case MOVE_SPEED)- so effectively the speed will alter - at a certain point in my program (22secs in). Here's what I have so far:
def UpdateJoystick1():
    #Get the joystick position
    x,y,z = joy.getPosition()
    #Move the viewpoint forward/backward based on y-axis value
    if abs(y) > 0.0001: #Make sure value is above a certain threshold
        viz.MainView.move(0,0,-y*MOVE_SPEED,viz.BODY_ORI)
    #Move the viewpoint left/right based on x-axis value
    if abs(x) > 0.001: #Make sure value is above a certain threshold
        viz.MainView.move(x*0.1,0,0,viz.BODY_ORI)
    #Turn the viewpoint left/right based on twist value
    #if abs(twist) > 0.001: #Make sure value is above a certain threshold
    #    viz.MainView.rotate(0,1,0,twist,viz.BODY_ORI,viz.RELATIVE_WORLD)
#UpdateJoystick every frame
vizact.ontimer(0,UpdateJoystick1)
def UpdateJoystick2():
        viz.MainView.move(0,0,-y*MOVE_SPEED2,viz.BODY_ORI)
vizact.ontimer2(22,0,UpdateJoystick2)
but it doesn't seem to make a difference at all - is it because it just comes on at the 22 sec point and then reverts back to the original joystick code? Would I need to insert starttimer and killtimer statements to initiate the two sections?
Any help - as usual - will be greatly appreciated!
Old 06-22-2009, 12:21 PM
UpdateJoystick1 is being called every frame. UpdateJoystick2 is only called once after 22 seconds. I don't think you need two different functions here. You could just change the value of MOVE_SPEED after 22 seconds.
Old 06-24-2009, 07:31 AM
Saz Saz is offline
I tried using this code
def MOVE_SPEEDCH():
	MOVE_SPEED=0
vizact.ontimer(22,MOVE_SPEEDCH)
but it still made no difference - I'm sorry I must be coming across as really dense - it's been a long week and it's only Wednesday!
Old 06-24-2009, 11:56 AM
You need to declare the MOVE_SPEED variable as global in your MOVE_SPEEDCH function.
def MOVE_SPEEDCH():
	global MOVE_SPEED
	MOVE_SPEED=0
The Python Tips page in the docs explains when you need to use the global keyword.
Old 06-25-2009, 04:49 AM
Saz Saz is offline
Thank you poppet - you're a star - works beautifully!
How to get the data from Logitech G25 racing wheel ? fuyonggang Vizard 4 12-18-2008 07:14 PM
writing joystick position to a data file Saz Vizard 3 12-17-2008 06:18 AM
Joystick Navigation Vinicius Lima Vizard 7 10-23-2007 11:42 AM
Facetracking and Immersion Joystick Vygreif Vizard 1 01-25-2006 11:56 AM
Basic Joystick Navigation Question Plasma Vizard 2 01-29-2004 08:08 PM
