				Stop moving after few seconds??
			Hello all,
	I'm trying to develop a application but now, I've got a problem: I shoot a ball against other balls and then these balls collide. Like a billiard game. These balls are not on a table, they fly across the air. Therefore I set the gravity to [0,0,0]. This works very fine. But now the problem is that the balls are flying too long. It takes about 10 seconds till the balls stop moving. But I don't want to wait such a long time. The balls should stop moving after 3 seconds. Is this possible? I searched the whole Vizard Documentation, but I can't find the relevant command. I would be very pleased about every information and help. Thanks a lot! Chrissy PS: Sorry for english mistakes  |
			the sound like you have to use timer. Could you please looking at vizard functions because vizard has a timer function.
	hope this helped you!  |
			But I only initiate the shoot. Afterwards the balls move automatically.
	Where do I have to set the timer? My code to initiate the shoot is: Code:
	vec.setLength(vizmat.Interpolate(1,400,power.get())) info.object.applyForce( vec, 1 )  |
			to shoot balls each time, try to define a shooting function, may be something like this
			HTML Code:
	def shoot():
    pass
vizact.ontimer(5,shoot)#each 5 sec
let me know if this helped you. Last edited by Moh200jo; 05-06-2009 at 04:56 PM.  |
	no - I don't think that's my problem. Look. I've got one white ball and 14 other balls. Then I shoot the white ball against the other balls. Code:
	vec.setLength(vizmat.Interpolate(1,400,power.get())) info.object.applyForce( vec, 1 ) And now it takes about 20 seconds, until all balls will stop moving. And thats my problem. Is there a command, like "stop moving all objects" or something like that?  |
			You could loop through all your objects and set their velocities and angular velocities to zero.
	for i in range (len(objects)): objects[i].setVelocity([0,0,0]) objects[i].setAngularVelocity([0,0,0])  |
			Hi Jeff,
	thanks for your answer. This is exactly my problem. Great! Is it possible to slow down the balls, so that they don't stop fitfully? Thanks a lot.  |
			Is there no idea to slow down the balls steadily?
			You could apply a small force opposite the direction the ball is moving.  Here a function is called ten times, the first nine times getting the velocity of the ball and applying a small force opposite to it.  On the tenth time the ball is stopped completely.
viz.phys.enable()
ground.collidePlane()
ball = viz.add('ball.wrl', pos = [0,1,8])
ball.collideSphere()
ball.applyForce([2,0,10], .1)
num = 1
def slowBall():
	global num
	#slow down the ball
	if num <10:
		vx,vy,vz = ball.getVelocity()
		ball.applyForce([-vx,-vy,-vz], .01)
		num+=1
	#stop the ball
		ball.setVelocity([0,0,0])
		ball.setAngularVelocity([0,0,0])
#call function 10 times
vizact.ontimer2(.3,9, slowBall)
| How to stop vizact.move | Jerry | Vizard | 3 | 06-04-2009 05:25 PM |
| moving and object by mouse but don't know how to stop the movement | nlfrnassimi | Vizard | 8 | 04-26-2009 08:23 AM |
| how can I stop an action? | nlfrnassimi | Vizard | 4 | 02-13-2009 01:59 AM |
| timer question | Elittdogg | Vizard | 5 | 10-10-2007 03:49 PM |
| moving viewpoint vs. translating Head_pos | bailenson | Vizard | 5 | 02-01-2005 02:51 PM |
