Old 05-02-2009, 03:51 PM
vTony vTony is offline
Haptic Device Shadows
We have a program which involves using a haptic device to pick up a screw from a colored box and place it into a hole with the same color (see "no shadow" image). We've started seeing a strange bug where if the user moves the haptic pen across the plane of the back of the screw boxes (the plane in the z-direction), some of the holes become darker (see "shadow" image). This only happens when the pen is within about a centimeter of this plane. There is a lot of code involved, so we were hoping there might be a quick/obvious fix someone could see just from these images. If not, I could see if I can produce a minimal case where the bug occurs.
Thanks in advance!
Name:	no shadow.JPG
ID:	314   Click image for larger version
Old 05-04-2009, 05:58 PM
That would be helpful if you could reproduce this with the simplest code possible. Maybe you have two objects stacked on top of eachother somehow.
Shadows in Vizard Vinicius Lima Vizard 4 07-26-2010 05:56 PM
Collision Trouble with Omni Device vNicolef Vizard 1 10-02-2008 12:32 PM
Plugins for other haptic devices xabbu Plug-in development 5 09-17-2008 05:39 AM
problem talking to usb device in Vizard Vbents Plug-in development 2 06-15-2006 03:08 PM
Phantom Device Getting Stuck vjosh Vizard 1 05-09-2005 11:16 AM
