Timer Question
I have a program that I want to run for 10 minutes. In those 10 minutes I want it to check for the time. For the first 3 minutes I want it to run one function. After the 3 minutes expires I want it to start another function for 4 minutes. When that expires I want it to run another function for the remaining 3 minutes. Do I use a starttimer and have the starttimer equal something and put the 3 functions in a loop so it keeps checking the time? Im looking for a good way to write this. Thanks Example: viz.go() . . . def function1(): "code" //end of function 1 def function2(): "code" //end of function 2 def function3(): "code" //end of function 3 |
Here is an example that uses the viztask module to control the timing of the 3 different functions:
import viz import vizact import viztask viz.go() def func1(): pass def func2(): pass def func3(): pass def MainTask(): #Run func1 for 3 minutes timer = vizact.ontimer(0,func1) yield viztask.waitTime(180) timer.remove() #Run func2 for 4 minutes timer = vizact.ontimer(0,func2) yield viztask.waitTime(240) timer.remove() #Run func3 for 3 minutes timer = vizact.ontimer(0,func3) yield viztask.waitTime(180) timer.remove() #Quit script viz.quit() viztask.schedule( MainTask() ) |
Ok thanks for that... If I wanted to do it via pressing keys and not a timer how would I do that. I got it to work but I have trouble after I go on to the next function... I can never go backwards.
IE I press 'a' to initiate def func1(): I then press 's' to iniatiate def func2(): If I press 'a' again I get an error. I assume I need a ontimer or something but I have trouble trying to figure that out. Any insight would be much appreciated |
If you just want to call functions based on keypresses use something like
vizact.onkeydown('a', func1)
vizact.onkeydown('s', func2)
| General question and question regarding arrays | dan12345 | Vizard | 1 | 01-15-2008 10:15 AM |
| Timer cycling correctly? | JMOwens | Vizard | 2 | 12-07-2007 09:57 AM |
| timer question again | Elittdogg | Vizard | 3 | 10-18-2007 10:29 AM |
| timer question | Elittdogg | Vizard | 5 | 10-10-2007 02:49 PM |
| Timer speed | Jerry | Vizard | 1 | 12-08-2006 11:01 AM |
