Loading morph mesh error.
I recently tried to load a 3DSMax mesh for my morph of a person gaining weight and losing weight. Before hand, I was able to use the morph just fine. Now, I get this error, and I'm not sure if there's been any documentation somewhere that I can look at to resolve it. cal3d : Internal error in .\coremesh.cpp(160) ** WARNING: Failed to load morph file: sportive02_f_mesh_fat.CMF If possible, how can I fix this? And what is causing this error? Thanks! |
This error means that the number of vertices in the morph mesh does not match the number of vertices in the base mesh. You need to ensure that both meshes have the same number of vertices.
Ah, that seemed to do the trick! Thanks!
| Problems loading WRL file | DrunkenBrit | Vizard | 2 | 01-29-2009 12:58 AM |
| Error loading plugin | djdesmangles | Vizard | 2 | 10-02-2008 07:13 AM |
| Error when loading a lot of avatars | dan12345 | Vizard | 7 | 07-28-2008 04:24 AM |
| Multiple Mesh Avatar Texturing | v-jbinney | Vizard | 6 | 11-13-2007 11:00 AM |
| The error window that couldn't | FlyingWren | Vizard | 2 | 12-02-2003 08:23 AM |
