Old 03-01-2009, 09:53 PM
RodRSpv RodRSpv is offline
Send a message via Yahoo to RodRSpv
Help with <viz.window>displayHTML()
I built two HTML files to be displayedi n Vizard but for some reason, the viz.window.displayHTML command is not working. i build the htm file in notepad and it is on my desktop. Do i need to put it somewhere else for Vizard to be able to read it? Any adivce would help.
Old 03-02-2009, 10:34 AM
The html file needs to be in the script directory or in your resource path. If the file must be on the desktop, then you need to specify the file using the absolute path.
Old 03-02-2009, 01:46 PM
thanks, that worked
