Old 02-06-2009, 10:53 AM
DrunkenBrit DrunkenBrit is offline
<node3d>.getPosition() returns [0,0,0] all the time...
I create a simple scene in 3DSM, export as either WRL or IVE format. All the scene contains is a plane, a few boxes and a sphere.
All 3 shape objects are positioned away from the origin. When i try and get access to one of the shapes:
scene = viz.add(scene.ive')
scene.disable(viz.LIGHTING,'')
sphere = scene.getChild('Sphere01')
print "sphere pos: ", sphere.getPosition(viz.ABS_GLOBAL)
I've tried printing the positions of all other objects too and also tried using viz.REL_PARENT, viz.ABS_PARENT etc which also return [0,0,0]
Any reason why this is happening please?
DB
Old 02-06-2009, 12:20 PM
If you right click on your scene node in the Vizard resources window and select properties, then expand the VIZARD_NODE you'll see your Sphere01 child. Expand that and you will see 'Sphere01-GEODE', which is what you want to use.
sphere = scene.getChild('Sphere01-GEODE')
Old 02-09-2009, 01:53 AM
Thanks for your reply; that worked fine! Could you explain why extra characters are added to the end of the node name? Why does it work like this to get access to a child node:
dummy = scene.getChild('dummy')
Yet to print the position i need to add on '-GEODE'?
Thanks.
timer question Elittdogg Vizard 5 10-10-2007 03:49 PM
Two animations performed by avatar at the same time michelcm3 Vizard 1 09-21-2007 10:51 AM
Printing of System Time Uttama_vizard Precision Position Tracker (PPT) 2 09-19-2007 03:38 PM
Avatar always returns in initial position pattie Vizard 2 08-31-2006 09:15 PM
Run Time Crash enkeli Vizard 4 03-08-2006 03:36 PM
